91TurboZ
- 48
- 2
- May 14, 2010
York,
Pennsylvania
I recently picked up and installed a set of used FIC 1680 High-Z injectors (as well as a resistor pack delete plug), but I'm having trouble getting the injector scaling to a value that makes sense. These injectors had been cleaned and tested by FIC on 7/1 (see the attached pic).
I started out by setting the InjBatteryAdj to the values specified by FIC, zeroing out global deadtime adjustment, and setting the global fuel adjustment to -73.5%, however the car would not start with these settings. I didn't really have any luck until I started significantly raising the global scaling. I'm currently running a -62.1% global and the car idles and cruises perfectly. The trims are in line and the airflow per rev is around where I would expect for a 2.3. I wondering why the scaling is so high for these injectors. -62.1% would be what I would expect for about 1100 cc/min injectors. I did check my fuel pressure and even set it slightly higher to about 45psi.
I have attached an idle log. Any suggestions would be greatly appreciated.
For reference, I am running V3 full, speed density with the flex fuel sensor. I had been running e85, but filled up with 93 to help set up the injectors. I was running the flex fuel sensor with my old 850's and did not have this issue with them. Other mods are in my profile if needed.
