FIC 1050cc 1 injector needs to be replaced. Options?
xxNocturnalxx
698
12
Nov 5, 2011
Tacomptan, Washington
So I just installed a set of FIC 1050cc injectors I bought off the classifieds. Only thing is the seller didn't mention one of the injectors was bad so I was wondering if anyone has sent injectors into FIC, will they clean flow test and replace only 1 or do I have to buy a whole new set. I will be contacting FIC today but just wanted some advice before hand.
If you send them all in and they see that one is dead and cleaning does nothing they will replace it upon your authorization. I'm not sure how much it would cost (if you divide $345 one injector cost about $86.25) they may even warranty it. Just print that sheet out and send them in a small USPS flat rate box $5 and check off you want either cleaning and flow test or just flow test. Fuel Injector Cleaning
