FIC 750 lower injector seals
spooln4fun
642
14
Jul 9, 2005
BELPRE, Ohio
Can you go to Home Depot Racing, and use the rubber grommets they provide? Mine came with a bad seal, and i made it even worse during the installation.
I know the 5/8 rubber grommet works great for stock injectors
Can I just get a larger one (that fits perfectly) for the aftermarket ones? Only reason I ask is because I can only find a complete kit, and I dont need all new seals.
Can you.... yes. should you maybe not. I did this for a temporary fix waiting for my new viton seals from FIC. I remember them being 3/8 gromits. They lasted about 2 weeks before they started leaking. This was good enough for me but only a temporary solution.
Good to know, well i got me news ones in and in the same spot on the block it started leaking again, so going to loosen the fuel rail, and try to re seal that injector,and check my spacers out perhaps that not in all the way and causing it to not seal properly:( just know i can't drive it until this stupid leak is fixed
