lower injector seals?
Siral3x
299
Mar 2, 2006
Ludington, Michigan
OK so here's my fuel upgrade.
I went big so, I won't be messing with it again :)
I just got a 12gal fuel cell, Aeromotive a1000 pump, SS lines, AFPR and PTE 880 injectors.
The injectors are not new and went to a shop and got balanced, BUT the lower seals on them got damaged...where could I get a set for 880cc PTE inj????
thx a lot guys
Get the Viton seals from FIC and you won't regret it. These are more resistant to heat and tolerant of high boost setups. I have a set and I love them.
Hope that helps,
Andy
Hope that helps,
Andy
I switched to the viton seals on my FIC injectors last year, much better then the factory seal or the reg rubber seal that FIC use to use. Just to verify the FIC seals will fit his PTE injectors? I know the injectors themselves are produced by the same manufacturer but PTE uses a different style end, just making sure the area for the lower seal is the same.
