few issues
ak-dsm
Jun 30, 2008
anchorage, Alaska
ok after my car is warm ill be driving take it out of gear and it revs to like 1900 rpm then settles after about 30-45 sec, sometimes it will settle to 1k then back up to 1500 but only does this twice then settles to idle. and if i try to rev it, it will go to about 1200 then slowly drop, it also misses a little at idle, and it wont hurt to set my car back to 450 injectors would it not knowing what they are?
ive replaced the isc with a new one from dsmisc mods are dsmlink, dejon tool upper intercooler pipe, tial bov, gm maft 3'' exhaust, 660 injectors a , 1tleast thats what the pervious owner told me,i have a fiav bypass plate but havent installed it yet not sure if i should yet, 4bolt rear, 2600 act, jdm motor without the cyclone im, ebc
another issue not sure if the greddy ebc selnoid is broke or what but i can lower or raise my boost its stuck at 10 psi, also i think my throw bearing is bad i get this kind of scraping grinding sound when my clutch is out dosent happen all the time then goes away after i push the clutch in
