1G Feramic Clutch noise perils.
dthquazi1
867
Jun 18, 2003
I just put the new feramic clutch in and when I rev it up with the clutch in or when i put the clutch in when shifting you can hear it spinning. It makes a scraping noise like it is trying to pick up speed or something. Does anyone know what could be causing this? I had the flywheel resurfaced too.
It sounds like you need more pedal travel. Your clutch disk isn't disengaging fully, it sounds like. Might be the throw out bearing, too.
the first one its what i am figuring. It was hard to get into gear so i took it to my dsm mechanic to adjust the clutch(have absolutely no patience after tranny install) and found out the clutch fork pivot ball was worn down so bad that it pivoted off the housing when the pedal got close to the floor. Iknow its not the throw out bearing cuz it only does it when the clutch is depressed all the way. I was just joping i didn't get gyped on my clutch disk.
