Feed Line for Evo3
Grimis
1,096
12
Sep 5, 2003
Jersey Shore, Pennsylvania
ok,
I've pulled my hair out for the last time. this past monday I thought my 14b blew, and it was a oil mess nightmare.
Ordered new feed/return's(yes 2, different story) and gaskets as well as an Evo3 from Extreme. All came fine etc.
I installed the feed line adaptor with the washer, and then the line. Was tight as i could get it with out snaping anything LOL...
So today, with the last nice day till sunday, i got the 14b off, and the Evo 3 on got it all buttoned back up and the feed line leaks at the turbo...
then the one water line, the rubber one for the turbo bursts so yeah not my day.
any input, on the feed line would be great... because I'm :banghead::banghead::banghead: this time...
yes it came with all new parts
should i take that washer out? and just use the adaptor?
its there standard 2g oil feed line from the housing.. the adaptor screws into the turbo.
If it is just an adaptor that screw into the turbo and the line feeds from the o2 housing then there should be no washer on that line at all... Just screw the adaptor into the turbo then screw the line onto the adaptor and attach the other end of the line to the oil filter housing and you should be good to go!!
