Fastest way to end pepper spray burning?
Ive got pepper sprayed its not that bad. and tomato sauce takes it away my bro in law works at a jail and has to get spray yearly and try to defend himself from a inmate ( all just training of course but its a just in case training )
Make it an auction, start the bid at 110, and whoever gets highest bid gets to spray your face.
ROFL :thumb:
Well I was just testing the can of spray, and i got some on my finger, which didn't hurt but i licked it, and uhmmm....ouch
I've gotten that and CS Gas
I've been gassed/sprayed to the point where it does not have much affect on me at all, my eyes get red and depending on the substance they may water. -charlie
I got the overspray of bear-mace.
me and my friend got sprayed, let me tell you it hurt like crazy.
To all of you: NO means NO!
:D
I eagerly await this video.
If your fair skinned like a red head or blonde it will affect you more, as in bad. And make sure whoever spays you does not directly spray you in the eye. It called the hydraulic needle effect and it will blind you. Use baby shampoo and LOTS of water. It will make you really appreciate living.
No, I'm not a ginger, or a blonde...I'll probably have my eyes closed and my mouth sealed tight. :p
wow, this is going to be good.
+1 on making you friend pay more on who sprays you.
Make sure he's spraying from more than 12 inches away from your face. This will prevent the hydraulic needle effect.
He'll probably be a few feet away.
Can you explain "hydraulic needle effect" more to me please?
Basically, the pressure in the can propels the stuff hard enough that it can be injected into the top layers of your skin. READ: Won't wash off as easily.
Just don't have them stand close.
An extreme example of this is a pressure washer.
There is research being done on using this method do inject vaccines in an ultra-fine mist.
You know how milk nearly instantly remedies the heat of habenero peppers on your burrito? have a trough of milk ready and dunk your head in it. If you don't want to douse you head in mild or other substance, don't douce it in concentrated capsaicin.
It should cause NO damage whatsoever. Capsaicin simply activates the nerve endings FOOLING your brain into thinking there's pain/heat/etc. There is no spoon.
I use this stuff at work all the time and what we are told to do to decontaminate the inmate is flush with cold water, remove contaminated clothing, no lotions or creams to sooth burning (it seals it in the skin), no soap as it can irritate the skin. I doubt it has oils in it as that would contradict the flushing with water theory. Hydraulic needle effect can also mean pushing the OC behind the eyeball (not good at all)..never heard of it going under the skin or penetrating the skin, and we use a canon sized OC sprayer that comes with a shoulder strap.
Like this
And this one
Key things to remember, don't panic, have someone lead you to a water source, don't rub it in, try not to inhale it when sprayed.
UPDATE: I am leaving right now for the spraying, video to follow in a few hours.
Damn I can't wait to see this video...I'm hopping in to watch this LOL
i was in the clink for some drunken behavior(not driving related). there was a dude in the cell next to mine acting up and got sprayed. a shit ton of it got in my cell and it fu$%^& sucked. the mist/cloud stayed in my room, and the asshole guard in the control room wouldn't even vent my door for some relief. i tried water and it was ok. the thing that really helped was my leftover milk from breakfast
