Factory Alarm Arm / Disarm Wires.
ArticNemesis
1,153
5
Jan 3, 2003
Myrtle Beach, South Carolina
According to http://www.vfaq.com/mods/wiring-gen2wir.html . The factory alarm / disarm wires are in the driver side kick panel. When one of these wires goes to ground it should arm / disarm the alarm according to which wire is grounded..
Anyone have any specifics on these 2 wires.. I have been through EVERY wire in the driver side kick panel (there's a ton of them...) Yet none of them arm / disarm the factory alarm.
I need help finding them, so I can get this compustar alarm working properly.. thanks in advance!
Yeah i kinda would like to know as well, as my car has an alarm switch, with keyless entry...yet the alarm never sounds???? I have no idea whats up with that!! ><
OEM Alarm Disarm Green/White, Brn/White, Brn/Blk (-) Either kick panel
Tie to ground to permanently disable the alarm ...........these wires are accesable behind the door panel. find the green and white wire and ground it there is only about four wires behind the panel. good luck!
Do you ground all the wires to disable the alarm? I have an aftermarket alarm, but my stock one still arms itself every once in a while.
behind the door panel is the green-white wire splice into that ONE WIRE AND GROUND IT. THER ARE PLENTY OF holes backe there or just make one. I believe that you alarm will arm itself if you lock the door from the inside after you shut off the car. if it does you will notice the green security light on the dash.
