fabricate a 4g63 exhaust mani to 420a?
420aStonerBlock
37
Oct 25, 2006
Littleton, Colorado
Hi guys i have a 96rs with the 420a motor in it and i was looking into turboing it. I know you cant just bolt up the 4g63 manifold so, I was wondering, since 4g63 exhaust manifolds are so easy to get a hold of could i could take the manifold and cut off the metal gasket or whatever the part that bolts to the head is called, and then cut the same part off another 420a manifold and then weld it together? Do you think i could do it or would it be easier to just make a whole manifold custom? I dont want to run crazy boost through it probably just like 10psi max for a good daily driver. Thanks guys.
