1G F4A33 Transmission Issues
92PLazer
Oct 27, 2024
Florida
Hi everyone I'm back to work on the Laser :D
I have a couple of questions regarding my current state of affairs.
When I got this vehicle, OD was ineffective when turned on. Once I go 40/mph+, the gear slips and I am essentially in neutral. I have been driving the vehicle with OD off for about 20k miles. Not ideal, but this is my daily and I am making it work. I also experience dramatic delays in shifting particularly when I start my vehicle and move from park to drive/reverse. Once the car does go into gear, the gears don't slip and move generally well. I attempted a fluid exchange on the transmission when I got it, I drained and added roughly 4 qts to "freshen" up. After the fluid exchange, of course no change to OD situation, and the shifting did not improve either. Fast forward to today, the delay has only gotten worse and I am afraid it's going to give out on me in traffic. My current plan of attack is a full fluid exchange, and replacing the shifting solenoids. I dropped the pan, and I can see the filter but not sure if I need to fully remove the valve body to access/replace them, if the filter has to be replaced, really any of the next steps in order to fix the issue. I'm really going off assumptions at this point and if anyone has some expertise in the area, some pointers would be appreciated. Attached are photos of the valve body, the dropped pan, the discolored fluid (possibly mixed with water/oil, please help confirm) and this strange bore that was filled in with silicone on the outside of the trans casing.
I'm a complete amateur, and now knowing I have a transmission issue I don't know if it's better for me to take everything apart or just drop the car off to a shop and let them attempt a rebuild. This car means a lot to me so I would rather work on it myself if I can do it and I don't trust any mechanics nowadays especially on a 30+ year old vehicle. If anyone can help identify the state of my situation and the best next steps regarding fixing the shifting issue and the overdrive problem, it would be greatly appreciated!
Just to confirm this is a 1992 Plymouth Laser RS with the 2.0 DOHC motor, naturally aspirated. I am pretty sure these use the F4A33 transmission but as I said I am an amateur and would love to be corrected if not the case :D
The fluid doesn’t look great. I’d go ahead and pop the end clutch cover off. Should be 5x10mm bolts, it has 2 spots you can gently pry to pop it off. Pop the snap ring off and take a look at those friction and steels. Here is a great video to watch of the OG auto DSM trans rebuilder. Take some pics and report back.
Also the filter is looking really rough. The plastic ones only have a single inlet where the factory metal ones are dual inlet. Here is the part number from NAPA, last time I bought some it was like $12-13 for one. ATP 19260, open the box at the store and make sure it’s a metal one. I’ve only gotten a plastic one once with that part number in the last 10 years.
Before we continue, huge thank you for the quick response and helpful insight. You guys rock.
Following Brandon's advice, I removed the end clutch housing. Looked pretty normal although the nasty oil is very present. A little worried about what is sitting in the torque converter and rest of the system, alas we will get there. Once removed, I removed the end clutch assembly. I watched the video and followed the steps up to where the snap ring is removed and the gears are able to come out of the assembly. Needless to say, they're fried to a crisp especially the one on top. Probably why my O/D is not able to function?
So I'm more than likely going to get the ITP performance and a new transmission filter, metal not plastic. Those two issues are apparent and hopefully will make my machine suffer less. However, how feasible are these fixes for the long term? Is a complete replacement of my transmission required to get my car back up and running safely? Can my issues be fixed with a rebuild of current components and a flush? I drove the vehicle without O/D and delayed shifting for around 20k miles. I'm afraid my negligence may have destroyed it :/ Any further insight on what to do/where to go from here is much appreciated. Thanks for all the help so far.
I think that’s a good start. When the end clutch goes it can cause quite a few different issues. Mainly because it’s most likely bleeding pressure off from the other clutch packs. That should resolve the O.D issue from my experience. I would love to tell you everything will be good after installing a new end clutch setup and the transmission filter but it’s not a 100% guarantee. This is just the quickest and cheapest method to address what’s 100% visually defective and lines up with the symptoms you have expressed. Now if you still have symptoms after that an overhaul will be required.
Thank you Brandon for the help truly, this gives me a good place to start. I will attempt to replace the clutch pack with ITP parts, along with new fluid, gasket for oil pan and filter. I have the 1992 Talon/Laser service manuals, and it says to fill with 4 liters of ATF. Is that too much? What I had drained out is probably less than a quarter of that, and I don't want to overwhelm the system especially after replacing parts. I only drained the pan, so if I undo the other plug and drain the remaining fluid, will it all fill via the dipstick hole? Should I go a quart at a time with the dipstick as reference having only drained the pan? Attached photo for reference.
I wouldn't be too surprised if the other clutches were also worn out.
I would not be either, given how disgusting everything is. If the aforementioned advice doesn't solve my symptoms, would this be my next step? Does this require me to drop my transmission assembly to access? Do the solenoids factor in at all?
I appreciate the help and corrections, and I know I have many questions that cannot be guaranteed but all I'm looking for is the next steps even if it's not a cakewalk. Thanks :D
  • For sale 1g Motor mount bracket GVR4, 1G MT transmission mounts
    Have these mount brackets as shown. Let me know if your project needs any of these.-GVR4...
    • pma1123
  • For sale 1g ACT 2600 PP + street disc
    Good used take out
    • pma1123
  • For sale 1g 1991 Eclipse GSX
    1991 Eclipse GSX $7,800 100,500 miles Clean Pa Title In Hand NO Trades Manual Transmission...
  • For sale 2.3 Stroker Galant VR4 Roller
    2.3 stroker block, forged rods and pistons. Needs to be gone thru (ballhone, rings and bearings...
    • brane_97talon
  • For sale New OEM style 2g Headlights
    New 2g OEM style headlights. Bought for my Spyder turbo conversion. Car long gone.125 shipped...
    • brane_97talon
