extreme boost creep help??
bowens1414
123
Oct 30, 2012
Bradenton, Florida
ok ill start right out by saying im on and egr solinoid delete therefor im running wg actuator boost only 5-7 lbs but ive been having extreme creep. now even though my actuator opens around 5-7 psi i have ridiculous boost, its not even creep i can spool about 15 lbs(before i cut it off) before 4k on the tach. ill be boost leak testing soon, but i dont think it could be a boost leak (that would cause less boost) correct? also ill be ordering a MBC soon but i dont know if this will have an affect. has anyone ever had this problem or know what i can check im just lost now ive tried everything.
Is it stock turbo? What mods do you have can you? uppdate your profile? Porting stuff is good. If you run 3 inch exhuast its more likley to want to creep.
i bought the car October last year it is stock turbo but the down pipe and exhaust look pretty big possibly 3in ill measure it tomorrow. also theres about 4 exhaust leaks after the down pipe. exhaust is in the budget also. whoever had the car before me did a vac line clean up. also my bpv is atmosphere dump. not recirculated. i dont know if that has affect?
The boost leak tester is a good thing to do on your dsm. Even though it might not show you can still have a leak. I did. I would just start out by looking at all the vacuum lines and turbo lines. Make sure there not cracked on the end. Also i had a problem like this and i had a leak on the BOV so might check that also. make sure couplers are tight. if you put hair spray inside the coupler before tightening it makes a better seal. hope this helps
I would think it wouldn't but then again it is under pressure. And i dont think it would matter if you welded a bung on it with a smaller nipple. I would just be worried if it is leaking. but then i could be wrong but i have had smaller bungs welded on my intake pipes and it worked fine.
