Kyromoto
- 227
- 0
- Jan 2, 2008
Fontana,
California
ok so if anyone read my post yesterday my RPMs spike real high on start up (about 3k) then it drops to a stall. I was able to modulate the throttle enough to keep it from stalling but it still spiked every few seconds. so today i check the ICS with my ohms tester and it was good. then i replaced the fuel filter (cause it looked bad anyway) and the RPMs still stayed the same. finally i got frustrated and just started tinkering. i pulled the throttle cable back a little bit farther. just barely beyond the point of contact on the TB. Then i pulled the BISS out just a little bit and between both of those i can get the car to idle just fine. now the problem is sometimes when i accelerate the car wont stop when i let off the gas till i hit brakes and force it to stop. does anyone know whats going on so i can get the RPMs to be normal, and when i accelerate to make it stop when i let of the gas? by the way only somtimes does it feel like the TB gets stuck open not always.
Thanks guys. you've been alot of help
Jeff
Jeff
