experiences and opinions on this brake kit
Do several hard brakes (without coming to a complete stop) and your "warped rotors" will go away.
Are you joking? That's what caused them in the first place.WTF
I'll give it a try anyway. I just have to secure everything inside the car so it doesn't shake apart or explode from the vibrations. ROFL
Not running that kit, but stoptech does make quality brake components. I would think they would be up to their normal standard. One other route to consider is the Baer decelarotors. Now they come with both drilling & slotting from the factory, which I wouldn't normally recommend. But they also come with a 3 year warranty against worping & cracking, I don't know of any other manufactures that offer this.
You have to do several continuously, until the shaking goes away. Rotors are a big piece of iron, they don't warp. What you have is uneven build up of pad deposits.
Go out and check your rotors for cracks. I drove for 3 weeks on a broken rotor after a track day, thinking it was just warped. OMG Granted I DID have little baby 1ga rotors.
No the rotors aren't cracked as far as I can see, I checked them when I rotated the tires a little while ago.
So I guess I'll go ahead and get this kit. I could care less about fixing these rotors, they've been resurfaced too many times and are probably well outside of factory specs.
