exhuast work????3inch..
xrotaryxtsi
Jan 11, 2006
Flint, Michigan
i want to run three inch from the turbo back to my apexi muffler. i herd you lose back pressure??? any help??
On a turbocharged car you want to lose as much backpressure as possible and still be able to maintain a safe boost level. Most people when they get a 3" exhaust with a stock car experience boost creeping or spiking. Creeping is when you boost continues to climb to unsafe levels during acceleration. Spiking is when it just blows past a set point then either settles back down or stays up there. On a completely stock car as yours I would recommend going with a 2.5" downpipe for now and 3" catback or a whole 2.5" system. A mandrel bent 2.5" turboback exhaust will make a noticable difference from your stock exhaust. Will also help with any boost creeping or spiking problems.
Yeah I would have to agree with the guy above myself. Go with a 2.5" turbo-back set up for now and when you start getting your car up into higher HP and further from stock then go with a 3". Check out Megan Racing's 3" set up they just came out with its cheaper then the name brand exhausts like HKS, and A'PEXI, and its better IMO.
G'Luck:thumb:
im not sure of your cars application but ill throw in my 2 cents ... Im running the apexi n1 exhaust and i love it , its 2.5 to from the o2 housing to the flex section then 3 inch all the way back . That might be ### you would be looking for , i honestly live the setup . Good luck with your car bro.
why upgrade twice that seems like a waste of money to me.:nono: Just get a 3 inch right from the start and forget about it.
dsmgrimreaper said:
3" means go faster, faster means funner....
Or it means boost creep or spike which means way to lean which means damage to an engine.
I agree. ^^^
xrotaryxtsi - Keep in mnd, that on a turbo car like ours, the turbocharger itself creates enough backpressure for the engine. You can safely run a 3" turbo-back without a cat. unlike N/A cars. If you end up getting that external wastegate set-up, go for a 3" turbo-back.
