3inch DP??
91 white tsi
229
May 21, 2004
Springfield, Virginia
will a 3 inch down pipe bolt up to the stock o2 housing. The shop i am going to have do it says it probably wont work but they havnt seen the car just the stock DP. well the pipe fit between the stock bolts or will it rub? I cant decide between 2.5 and 3 but was thinking go big or go home but if its a problem i might just have to go with 2.5. opinions , ideas???
I don't think a full 3 inch will fit between the two bolts. Just have them bottle neck it to three then run three all the way back.
You could hack the exhause off after the first 90 degree bend then just add three inch piping after that.
i'm telling you from my own personal mistake NO it will not fit, i bought my friends evo III o2 housing off of him and it bolts up perfectly
BS.
I have a full 3 inch. It will fit after some minor modifications. It is a PITA though.
THe problem is the o2 housing bolts. You can't get a nut or socket because they are so close to the pipe. I had to make some minor dents in the pipe to get the nuts to go all the way on. A crows foot came in handy also.
Easy fellas. I just measure the flange of the stock o2 outlet, the OD on the side without stud is exactly 3" so I will have to say no. I don't see how it will seal. Like devilsperm, it was not easy with my 2.5".
Both you two settle down.
Jason your post could have done without the insult. Not necessary.
byondevl: We have a swear filter for a reason don't try and get around it.
byondevl said:
BS.
Then it doesn't fit.
I wouldn't call BS on something then say it needs "minor modifications" to fit. :rolleyes:
As oposed to making a 2.5 inch neck down and saying it fits?
As I said, it was a pain, but with two small indentions, it fit and sealed fine.
Seriously, how many "bolt on" parts are out there that we have to make small adjustments to , to work right?
LOL where'd my post even go? sorry bout the insult just shouldn't have to bang things to get them to fit right...
