Exhuast Poppin losing power
SpoolN
386
Jan 20, 2003
Coventry, Rhode Island
I put on the N1 exhuast and downpipe and around 5000 to 6000 it rappidly pops and i loose a significant amount of power till i shift and it goes to a lower rpm. THen i just installed my j pipe off my evo turbo and now it happends around 4500 could this be becuase of exhuast leaks, air leaks, or boost leaks.
That sounds like either an ignition problem, really really bad intake/boost leak, or a pre-turbo exhaust leak. The first and latter are pretty easy to check.
If I were to be money it'd be the exhaust. Pull off your heat shield on the exhaust mani and check to make sure all the nuts are torqued to spec.
Well one of the studs on my o2 housing is stripped so one side fo the downpipe isnt bolted down tightly could that be it im getting that fixed this week. Also though my idol is ####ed up i got an automatic in nuetral and in park it goes from 1000 to 1500 and back down constintly till i put it in gear.
I am not sure if you have or not, but if you haven't built a leak tester, I would try that. Make sure the car is warm before you check for leaks though, or you might not find em all, if there are any. www.vfaq.com has a faq for building one. Good luck, sorry I can't help more, but I am not a wizard at this stuff yet. :talon:
Haha thank you for the info tho??? What is that supposed to mean? How do you expect to get help if you don't respond to my question? I know I am not a wiseman, but you ought to at least say if you have done a leak test or not???
Haha I was planning on doing that today. LoL. I looked on the Vfaq and copuldnt find were it was to build one what sectin is it in?
