2G Exhaust stand still.
wiscanidsm
Aug 17, 2010
La Crosse, Wisconsin
Hey there, i have a 1996 talon tsi awd, and i have been working on her for the winter, and i ordered a new Megan racing dp with the cat delete, it fits on my aftermarket cutback but i don't know what brand it is, it came with the car, and the previous owner didn't know. And so I have taken the old stock dp, and cat off, and tried to get the new one on and came to realize that they must have sent me a fwd one because it directly intersects with my transfer case. And if i put it in the spot where it's supposed to go I have about 3-4 inches of gap. So I figured it would be a easy fix, call extreme psi and get the right one, well I talked to a rep. And they told me that if it's the two piece one from Megan then it is correct and that i would have to call Megan racing.
Kinda fishy i though, but still i called. And after not getting a reply from Megan racing which i expected i called extreme back, and they told me again that i had the right one that the awd version came in two pieces and at the fwd came in one.
So there i am, with a problem and no solution, and it's not like this is a cheap part necessarily so I would like to know if I need to buy a spacer? If they even have those? Or if i am correct and they just sent me the wrong part. Over all i would have thought extreme psi, whom I have had nothing but success with, would be a little better then this.
Please help a newb out.:banghead:
my awd megan dp is one piece and has only the bend to make it go under the car. It should run right next to the driveshaft. I would send them a picture and show them what you got going on. I too have had no problems with extreme kinda fishy if you ask me
That's what i thought, so yours is one piece? Hw old is it? Because then i need to call them back to figure this out.
They told you the DP should be 2 pieces or the catback should be 2 pieces. Cause if the fwd catback is supposed to be a 1 piece, that person is an idiot. Because how the hell would you get the one piece exhaust over the rear crossmember? Not possible.
But then that means that if i have a bad part, then will they take it back? Because i have a 200ish buck exhaust that i cant use then.
