Exhaust Manifold crack
joeym4130
296
Dec 8, 2003
philly, Pennsylvania
Could a small crack like this in the exhaust manifold cause an idle problem? like sputtering and stalling? or no?
yeah been thru about every idle surge thing possible haha.... as far as ECUs, ive changed it with another i got off the trader, but with my luck i now have two bad ECUs haha....
instead of just swapping the ecu, you could find a good one...then have the capaciters replaced. t hen try your luck.
yeah but finding a good one is a problem for me haha...i know no one with a DSM... :( Is it possible for the ECU to crap out even w/o leaking caps?? Because on both of mine, the ECUs caps look good/smell good...
hmmmmmmmmm that mani doesnt look to bad. If ur going to atempt it, use some JB Weld. fil it up, Grind it down. Its a stock mani anyways!!!!!
