Exhaust choice,,, turbo in the future
l6u9k6e9
148
3
Jan 9, 2003
Dover AFB, Delaware
Hey, i was thinking of buying the Tsudo N1 exhaust, ive heard only good things, My question is ,,, I plan on installing a star stage 2 turbo kit later on, and i want to make sure that the tsudo n1 catback and the stage 2 turbo kit will mix and mingle just fine... or would i be better off spending money on a different exhaust? Thanks for the help.
I do believe that the piping diameter on the Tsudo units are 2.5" so you should have no problems when you are both naturally aspirated or with a turbo
yea you shouldnt have a problem with the tsudo but since u are going turbo you might want to think about a 3" exhaust system. i would suggest looking a thermal r&d's 3". the gst system will bolt up fine to ur rs/gs and will flow much better when you go turbo in the future.
-rick:thumb:
the tsudo is the shiznit yo :thumb:
lots of us on here have the 2.5", and it'll work just fine with a turbo, but if you wanna go with a 3" exhaust, it will definitely give you a quicker spool up time :rocks:
Thanks guys, ill order one today after work most likely... I have one more quick question though, will i have to do any welding when i go to put it on? My friends say yes, other people say no. ?? Which is it?
Thats awesome!, im going to try and put it on my self... LOL we will see how that goes. Any suggestions as to what down pipe/ headers i should get? Keeping in mind that i do plan on having that stage 2 turbo kit put on later ,,,, ?
Don't waste your time on either if you are going w/ a stage 2 as you will have to throw both out....
One suggestion when you install - don't use your jack to support your car, spend the money and buy 2 pairs of jackstands and lift your car off the ground safely.
why would i have to throw away the exhaust ? they just told me that it would work with a stage 2 kit.... ?"? Im confused :confused: :cry: Im in the process of gettting the tsudo n1 exhaust now.... I will most definately get a stage 2 star or Hahn turbo kit. CAN I OR CAN I NOT USE THE TSUDO N1 WITH THE TURBO KITS? someone plz help?
no no he means that when you get your turbo kit, a header will be useless...the exhaust system will be fine whether you are NA or with a snail.
yup yup, you'll love the exhaust :thumb:
good thing that got clarified huh :p
your turbo manifold would replace the headers, so no point in buying them ya know :cool:
