Exedy Cerametallic Clutch?
90GSXDan
224
Aug 8, 2004
Long Island, New York
Hey everyone,
I just ordered a Exedy Cerametallic Clutch, and I wanted to know how good they were?
I know its going to be pretty stiff for driving, but what can they hold, tq wise?
Im getting it installed next week with a rebuilt transmission.
I plan on going 20g, with a front mount, safc, 660s, walbro 255, GM MAF w/ trans., maybe cams, ported 02, ported 2g exh. manifold, tial 38mm wastegate.
I already have a boost controller, turbo timer, intake, exhaust, gauges, and the k&n drop in.
Anyone?
Thanks
Dan :dsm:
I have one. How much torque it holds depends on whether you ordered the thin or thick disc. I ordered the thick disc which holds 82% over stock, the other holds 63%. That should be enough for what you're installing. Don't worry about the clutch chatter at first, it goes away very quickly. It's not that stiff for driving, one's only 1940lbs clamping force, and the one I have is 2160lbs. Here's a link for some more info on them.
http://www.prostreetonline.com/buy/exedy_cerametallic_clutches/mitsubishi/
I too, ordered the 2160 clamp force. Im looking to push about 350-375 awhp, and wanted to see how much it could handle, if not, after this one, Ill order a much stiffer/more torque capacity clutch.
Thanks
Dan :dsm:
