nickferguson08
- 34
- 0
- Nov 5, 2007
Florissant,
Missouri
Ok so rebuild 7 bolt. Cylinder 4 is missing because it needs a new rod bolt ( I tore it apart again because I had to replace the rings due to massive blowby) but i thought id measure the endplay just since when I drove it when the rebuild was initially done, the rpm's would drop real fast every time the clutch was pushed in...so i measured the end play and when i would pry on it, the whole damn thing would move. it moved .050 in one way....i could pull on the harmonic balancer and move the whole crank back and forth slightly.. now since i have brand new bearings (ACL Tri-metal race) in there with 400 miles why is this happening??..what do i need to do??..besides get a 6 bolt..??
