ECUflash evoscan timing function
DSMopar
615
15
Oct 6, 2007
Vista, California
I have a 95 talon and I'm using evoscan to log and tune in conjunction with my SAFC2. On the evoscan website they mention the timing equation should be x-10 instead of x-20, obviously the difference being 10 degrees. However if I put in x-20 I have 15 degrees of timing at idle at around 8-900 RPM, and 22 to 24 degrees at WOT... I'm thinking it should be x-20 despite what they say.
Someone please verify as I'm running a 6-bolt with a 1g CAS and need to check my timing.
No one has a 95 with evoscan?
