daren_p
DSM Wiseman
- 4,604
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
When I first had my mbc installed I could boost more then enough. When I installed my greddy profec type s the most I can boost now is 18 psi with the high setting turned all the way up (gain is about 1/3 of the way up, I could get abit more boost by turning this up but then I get huge boost spikes between shifts & the boost oscillates) So initially I though I had a problem with my ebc. So I disconnected the pressure source to the wg and I could hit 21+ psi. Next I connected the wg directly to my ic pipes. With it hooked up this way I would initially see 8 psi when the turbo first spooled & then would creep to 12 psi by redline. Is this the normal wg boost setting for the evoIII? I thought the wg was 12 or 14 psi? I believe the way the greddy unit works is that it is a multiplication of the wg pressure, something like 2.5x so that would work out about right. Is there something wrong with my wg? I would like to run about 20 psi on the street and about 22 psi at the track.
I'm assuming a leak test was already done?
Ya I know, but I wanted to have shinny knobs in the car and 2 boost levels that I never switch between
