Evo3 16g with down firing housing
newtodsm97gst
289
Oct 23, 2011
Lewisville, Texas
does anyone ever replaced a evo3 16g housing from kinugawa down firing housing? They claim that it will fit, but need to know of anyone ever tried it. Any fabrication need to do with the internal wastegate?
Mmmhmmm.
Absolutely zero chance of the stock actuator working with this cover in any way. If you're buying the downfiring cover as a way to improve performance, move on....the money you'd spend on a housing and new actuator would negate any small gain in performance it may give. In reality, a surge-ported cover may actually hurt peak airflow a bit.
Good to know Justin, and thanks for that info. Reason I'm asking is that I'm currently on a process of rebuilding my evo3 and I wanted a down firing turbo and also my evo3 16g housing thread for the j pipe is stripped but can easily fix. Also I can run external wastegate if internal is an issue.
Common problem....just heli-coil the stripped j-pipe hole and it will be as good as a new one.
I'd say for simplicity if you want to stay with an internal gate, run the stock j-pipe cover. If you're considering going external, go for the downfiring cover...but I wouldn't choose one with the surge-porting.
