EVO III BIG 16G Question!
BlakeGSX
Feb 6, 2004
Okmulgee, Oklahoma
Ok, i just bought a evo 3 big 16g for my eclipse, well i noticed that there is no nippple for a air line to run to the turbo...it is internally gated but where will i run that line to? im confused! please help.
No, just run it directly from the nipple of the WG to the boost controller. I know which nipple you are talking about cause i thought the same thing when i swapped out my t25. But you will be fine without it.
Install a tee in the line going from the intake manifold to the bov. Now, run the line from the tee to the mbc. Then the outlet of the mbc to the wg actuator on the turbo. If you have no mbc, get one.
