Evo Brembo rotors on Eclipse?
babiebluboi
112
May 25, 2004
San Francisco, California
I heard around that the Lancer Evo Brembo rotors would fit on a 2G. Is that true?
And if it was to fit, would I need to change my rotors? I already have Brembo front and rear rotors, but they're stock size.
The rotors should fit seeing as both cars have the smae bolt pattern but the trouble would be the diameter. Most likely they are larger than stock eclipse rotors so your caliper would not work. If you fabed up a caliper relocation bracket maybe, but then why not buy a big brake kit?
Not sure what you mean? Do you mean will the calipers fit? Or you have upgraded calipers and you want the rotors?
Either way, it shouldn't make a difference right? I doubt anyone will be upgrading thier evo brakes anytime to sell the old ones cheap. My point is, if your gonna buy evo brakes there is no point not buying brembo brakes that are set up for your application.
But to answer your question, no. You would have to replace rotor, caliper, spindle in which caliper mounts, and larger wheels.
That is so thah sexssss.... And uber illsicknasty!
Anyone try on a 1g?:confused: .. we don't have double front wishbone....
