Evo 8 pistons on 6 bolt block
RedTsi_PR
227
Jun 19, 2011
San Lorenzo, Puerto Rico
I know the pistons fit on the 1g rods using the same method as putting a 2g pistons but my concern is the evo 8 piston has the pin a little up compared to the 1g pistons.Does the evo 8 pistons are gonna sit lower on the 1g block?
Anyone who can share a little knowledge on this? I only need to know if the piston sits lower than the OEM ones
The Graveyard sells Evo pistons I think you can even order them fitted to rods from them. But they claim the 8.8:1 compression ratio is reduced on a DSM engine to aproximately 8.5:1. Not stating that as a fact that, thats what the compression ratio is on a DSM. But thats what they claim.
Just reference there page, they have a little short right up on it. And from the sound of it love using Evo pistons as a great affordable upgrade. Supposedly higher compression, skirts are coated, and 20% lighter than a 2g piston according to them. Also stronger than our stock pistons.
The ONLY question I have about Evo pistons in a DSM block, is does the valve releifs being on the wrong side when installed in the DSM block cause any potential interference problems? Or maybe because of the different location of the wrist pin this prevents any potential problems...but then how does it effect quinch? I think I recall the DSM Graveyard stating that the change in writst pin location was actually benificial some how. If the damn internet wasn't slow as #### here in Afghanistan i'd pull there page up and quote it with a link... shit I might anyway got nothing better to do.
DSM Graveyard - Your #1 Source for DSM Parts!
"Evo 8 Piston
Virtually the same as the Evo 9 (Only oil ring land depth changes .010")
Top and Middle rings interchange, Oil does not unless .040 oversize.
8.8 to 1 compression w/ Evo Head
8.5 to 1 (Give or take depending on Head Gasket) w/ DSM Head
Very good daily driver performance piston for DSM's"
"This is a New OEM Evo 9 Piston with the 22mm Wrist Pin. This is our best known OEM Piston we have found, and it is our newest upgrade to our Frankenstein Line. These will swap directly into a 7 bolt engine, and we can bore 6 bolt rods to fit! This piston is also way lighter than the OEM 2G Piston, Look in features for more details! WE CAN PUT THIS IN YOUR FRANKENSTEIN!!
Features
22mm Press Wrist Pin ( Cannot use Full floating rods)
Skirt Coating
Machined Top Surface
Thicker Wrist Pin
20% lighter than 2G
Better heat transfer
Different than Evo 8
Does not include Rings ( We have them available!)
Huge Value Race Piston
Great High HP Daily Driven Piston
**Machine Shop Info**
Skirt to Bore Clearance Spec. .0016 Minimum Clearance.
Dots face front of engine. Valve Reliefs are backwards compared to DSM Pistons."
I have the evo 9 pistons and rods in my 7bolt. They fit perfect. I wanted to use 1g rods with 2g pistons but couldnt find any 1g rods. Didnt have enough money at the time to get manley, eagle or wiesco. :( but its running strong just need to fix a few oil leaks and its good gonna try to hit 350hp :D good luck man let us know how it goes :)
