Evo 8 pistons on 6 bolt block
RedTsi_PR
227
Jun 19, 2011
San Lorenzo, Puerto Rico
I know the pistons fit on the 1g rods using the same method as putting a 2g pistons but my concern is the evo 8 piston has the pin a little up compared to the 1g pistons.Does the evo 8 pistons are gonna sit lower on the 1g block?
Anyone who can share a little knowledge on this? I only need to know if the piston sits lower than the OEM ones
Im also interested in this as i have a set of eagle 6 bolt rods that i also would like to fit on evo 8-9 pistons.
Any one have any info on this?
Just get aftermarket pistons that fit the rods. If you already have aftermarket rods, why spend the money to modify the rods? You'll end up spending more money on that setup than you would for some manley pistons.
Also, with Evo pistons, you don't get the 8.8:1 compression because the Evo's head is 4ccs smaller -- just like the 1.8L/1.6L head.
doesnt sound right, you say the rods are the same but the piston pin location is higher, well the deck hiegth would have to be shorter in the EVO block, but from my experience, location the piston pin higher allows you the use a longer rod and increase the rod ratio, why would you relocate the piston pin , keep the short rod, and lower the block, it doesnt ring true
the dome volume on an evo 8-9 head is smaller then a dsm head. so if u use a stock dsm head gasket which i believe is 1.3mm thick it drops the compression to right around 8.5:1.. its 8.8:1 in an evo 8-9 engine
It's a LOT closer to 7.8:1 in a dsm block. Do you think that 1/8" gap between the top of the piston and the top of the block means nothing? The evo uses a 43cc head, vs a 47cc head on a DSM. That right there drops the CR almost half a point, to ~8.3:1. Couple that with the 1/8" gap the piston has..## right back to where you started with a stock piston!
Its a .5 difference between dsms and evos regarding compression ratio. I don't get why people just don't buy a true forged performance piston. The 6 bolt rod and a manley piston would hold a hell of a lot of power with some ARPs for rod bolts.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
