2G Evo 8 Maf and injectors in 2g
TehRiceBandit
317
53
Dec 12, 2013
Bay Area, California
Before you flame me. I've been searching for information for awhile on this swap. So far, I haven't found any definitive answers.
My question is by swapping the evo 8 maf and injectors into a 2g will the car run relatively smoothly and safely to daily? Looking for someone who has done this for some input. I don't have a wideband or logger but I'll be doing a Dyno next month and it will have a A/f reading so I'll be able to test it.
To make the most of it it would be better to use an Evo 5 onwards Ecu as well. Not sure how well it would work on your standard ECU?
There are a couple of users who have done this swap without (much, if any) additional tuning - but they also had Link/ECUflash. Does that mean that it will be safe for every car? No.
Did each of the folks who've done it take readings, make logs and investigate if it was safe for their cars before using it? Yes.
It's a fine road to go but I can't recommend it without a logger/wb02, especially if you're going to put it on the dyno to find out.
Evo 560 injectors have zero dead time like the stock 450's. With the extra flow reading in the 3g maf (what the EVO has) and the larger injectors you can be fine with the stock ECU. Just install a wideband and watch your AFR's, This is the same as the 2g MAF/560 injector setup in the 1g's. Works great. I ran like that for almost 2 years. Perfect afr's, car ran like stock but handled much more boost. Make sure you upgrade your FP too.
