Evo 8 Engine into 2G?
fmars62
372
3
May 30, 2011
Middletown, New York
Just wondering if this is possible or is anyone has done it, I searched but didnt really find any solid stuff. Like I am talking the engine or engine and tranny. And then will the evo 8 ecu work with the 2g dashboard and whatever else? Thanks.
Well, anything that you have to make new mounts and what not is difficult but you can always give it a try. Just know its going to be costly but to each his own.
Lol edit - is this for a n/t or a 4g63!?!
Ahh, yeah just did a little more research and saw that its pointless because a built 6 bolt is just as good.
But why can you only do that on a n/t? Why not the 4g63?
Motor is 180 degrees different, to me is worth it if you start with a GS, why? Because the motor would be on the passenger side which is way more balanced than the DSM 4g63s and its also unique, would i would go the star mile and AWD swap too, Keep in mind i'm talking about cornering here.
A little rough but here is an example.
So the 420a engine have the same mount positions as the evo 8? SOrry, never looked into 420a's
Yes it is very close, it would need some modifications done to the mounts but, if you own a welder its easy task, nothing to be scared of, but if your budget is limited i don't recommend this.
If 2gs are College girl cars then 3gs are for gays, LOL :p
  • Wanted 6 bolt NT water pipe
    • chrisman287
