EVO 3 O2 Housing Issue
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
So I'm swapping 14b turbos because the one on there now is blown. I have the 14b with an EVO o2 housing and the new turbo I'm putting on doesn't have the one stud on the o2 housing side and I cannot remove the old stud on the blown 14b. What are my options? I don't have time to order a new stud online I need to have the car running by tomorrow. It is near impossible to get a bolt in there due to the way the housing is setup (which is why I'm guessing there was a stud in that particular hole). Could I maybe get a metric high grade bolt and cut the head off to use it as a stud?
If you don't have time to order the stud online have you checked with your local Mitsubishi dealer to see if they might have it in stock?
