EVO 1 manifold ? does it fit 1g ?
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
hey guys does an evo 1 manifold fit a 1g TSI? if so is it better then a 2g manifold ? as good as evo 3 manifold ?
thanks
these are the pics I have
ah I try to fix them. Anyways dont need the pics does an evo 1 manifold fit ? hows the flow?
Chances are it'll bolt up fine to a 1g head, but the intake ports will be shaped differently. The intake ports on the manifold will be shaped like the ones on a 2g head. Everything I've read and seen shows the EVO1-3 intake manifold to be pretty much the same. It'll be an upgrade for a 2g, downgrade for a 1g.
would it be a downgrade?
thought 2g manifold flow better then 1g and evo 3 flow better then 2g
was wondering if the evo1 manifold was same as the 3
Thats a 1g manifold,worthless IMO, just get a ported 2g manifold
the evo was running an small 16g
correct me if I am wrong, but the 16g turbos utilized a 7 cm housing and the manifold outlet would be larger then the 1g and 2g.
Evo 3 manifolds are now cheap enough, under 190 easily, that you should upgrade to that. Its been proven to be the best manifold Mitsubishi produced during the dsm era.
