evap code
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
I keep getting the code p0443, the thing is I have the solenoid hooked up, I even replaced it with a different one and the code still comes back. I do have the emissions removed on the car. Its on my 99 eclipse gst spyder. Any suggestions would help.
thanks
Just a thought but you might wanna hook the emissions back up.... Then code goes away... you can disable the code or turn it off if you have link
I thought the codes wouldn't appear as long as you had all the sensors hooked up.
well I just went out to double check that I had everything plugged in and i don't have the middle sensor plugged in. I cant find any plugs for that one and the middle one is the EVap sensor. where the freak is it on a 99
