ETS FMIC....intake????
dsmmack
177
6
Nov 7, 2004
Winnipeg, MB, Canada
OK! i've heard many different things and i want to hear this from someone who has the 1G ETS FMIC 7" Street installed, i have a 4" FP intake that routes it to the stock air filter location and i was wondering will it work with the fmic? or will i need to order a different one once the fmic is installed? i'm going to be running a 3.5 maf setup and i know there is an intake that ETS sells that routes it to the stock i/c location, which i don't want because i can easily see myself sucking up water which is never good, SO if anyone knows if the intake will work or not please reply, thanks guys!
It should fit fine... I'm running an ETS Street kit & a 2G MAF --> 3" (DeJon Tool) intake and I still have PLENTY of room left for a 4" pipe.
See...
ok guys thanks, i'm going to be running a 3.5 inch gm maf setup but i'm sure the routing would be the same, so the 4" should fit thanks guys!......if anyone else has any pictures of a 1g running a 3.5 gm maf with an ets fmic that would be awsome thanks!
