Eprom tuning- Extended Fuel and Timing Maps- help!
toofast82
3,037
20
Feb 8, 2005
Tinley Park, Illinois
Im going to be writing my own eprom using tunerpro and i have been unable to locate the extended fuel and timing map spreadsheet and how to execute the code. I believe there was a site that was Kyle Tarry's romedit but it seems to be down. I have heard that it has that as well as code to eliminate phantom knock etc. ive searched the yahoo group and havent found what im looking for. if someone can help me out or pm me what u have. im definitely looking for the maps as well as phantom knock, fuel cut, thanks in advance
do u use tunerpro? so i uploaded a bin and xdf and i had a page w/ certain things like injector size, octane reset, etc. i edited the hex to execute these codes. now my timing and afr tables all have the same values across the board. now do i have to go in and edit the whole tables. i thought they would already show the stock settings?
They will show the stock tables. Sounds like your offset is not set correct.
I use a old version of tunerpro cause I never got the xdf files to work right.
