2G Engine won't start p0335
caseyty13
32
May 24, 2010
olympia, Washington
So I rebuilt my engine. It's a long story for that. Go to start it and it won't start. Cranks but won't fire. It threw a p0335 code for the crankshaft sensor. So I replaced the sensor. And tried to start it and it won't start and threw the same code. Checked the wiring and there is no sign of damage at all. The thing is my battery light is on and so I think the alternator is bad. Could that be causing the sensor to trip and not work right. Or what else can be causing it
p0335 can result from a number of faulty components, including the starter (or starting circuit). I got p0335 a few times when I first acquired my 2g, which had a funky starter, esp when the battery was low. Never saw it again after replacing the starter. Starters are hard to diagnose if it's something intermittent, but if your car doesn't start at all that could be the problem. You could just have a bad ground in there somewhere.
Starter is good. I had it checked out too. So I'm checking all of my grounds next
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
