engine swap help non turbo
OregonJB
Mar 5, 2008
Brownsville, Oregon
Hello,
I am new to this forum and only posted once about using a turbo block in my non turbo car. as luck would have it I found a 92 non turbo engine with a little over 5000 mi on it after fresh rebuild. My car is a 90.
So to the issues I am having. got the engine in with no problem and put new timing belt and balance shaft belt in. I had to change the coil pack and throttle body and small module under coil pack because of differences in connections. I also had to change the cam positioning sensor. The car is timed correctly..... the problem..
1. The car when given full throttle will not go past 4500 to 4700 rpm it will buck and kick and feel almost like it is starving for fuel. When driven under normal condition (half throttle) it is much better.
2. engine has vibration at 3000 rpm
I left the 92 fuel rail and intake on the car....
What did I do wrong? I fully checked the balance shaft when we did the timing kit.....
Any help?
Jeff
I changed from the 92 to the 90 components...
I did un-screw the tps thinking I could just change that over, but it was different than the 92 It was just a straight shaft. does the 90 adjust?
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
