Engine Swap 93 DL FWD from 93 tsi AWD
socci
Oct 5, 2004
Providence, Rhode Island
Is it possible??? If so anyone have some layouts i can use???? i have couple friends who kno alot about cars to help me....I have the tranny for the DL and stuff.. I just wanna put my 93 tsi AWD motor in it...
thanks
Anything is possible with enough money, but it would be WAY cheaper to just buy a AWD shell.
socci said:
y would if be cheaper if im installing it myself?
Becasue there are alot of thing that are involved. More than just putting the motor in the car. You have to get a turbo wiring harness, tranny (for strength), ECU, lots of things. It has been done, but those who have done it have said they would rather buy a turbo car and start from there.
yah but i cant use the turbo wiring harness from my car? that i crashed and use my ecu and shit? andd that shell comes with a tranny i can use.
Ok, here we go again.
This is for a non-turbo engine to turbo engine swap. Custom fabrication WILL be needed as everything doesnt just fit easy. I am not sure about the AWD engine to FWD tranny fitment .. this guide was for an engine out of a FWD to FWD.
1. complete turbo long block (block and head including internals and bolted attachments such as oil pump and such).
2. mass air sensor -
3. fuel pressure solenoid -
4. turbo intake manifold and throttle body -
5. turbo exhaust manifold - .
6. turbo and related cooling and oil lines -
7. intercooler (side mount or front mount) - you will need!
8. intercooler piping-
9. turbo fuel pump -
10. BOV -
11. turbo injectors -
12. injector resistor pack -
13. downpipe -
14. wastegate solenoid and mbc -
15. knock sensor -
16. o2 sensor -
17. thermostat upper and lower housings -
18. coolant cross pipe -
19. oil filter cooler -
20. turbo ECU
21. turbo tranny - N/T tranny will break fast
after you have all this.. its going to be a long ride to completion
basically its like doing an engine swap, tranny swap, and installing a turbo kit all at once but at the same time.. the swap doesnt just fit up.
