engine simulation
sharky559
191
Mar 6, 2010
Sanger, California
Ok so i was watching this clip on you tube, this guy had just finished cleaning a ecu and socketting job. to see if he did a good job, he connected the ecu to this simulator to see if everything work. has anybody done this. if so can someone tell how to get one:rocks:
LOL...Let me see if I can find a link. I think your talking about Jeremy, over on Hotrodcoffeeshop.com. He does rewires for us guys running rear wheel drive and wanting to clean up the harness. Its connected to a battery and I cant remember what needs done from there...give me a few and I'll re edit...a link to the video would be good though.
not at ALL what I thought you were talking about. Thats pretty BA man...but I have NO idea how to help ya with that.
A Bench Harness is fairly easy to build, just need a 12 volt supply, ecu plugs, and wire.
I use a Bench Harness for Flashing ecus out of the car and testing new code.
A Engine Simulator would be more difficult on a DSM then a Honda because of some of our sensors.
The Honda use a MAP for airflow which outputs 0-5 volts, our MAFs output a frequency.
Also our CAS and Crank Sensor output a frequency, but the two signals must be a certain amount of degrees out of phase from each other, and the CAS has different size waveforms for each cylinder.
But it is possible with a little electronics know-how. The CAS/Crank signal generator will most likely be the most difficult part.
