wb wiring for narrowband simulation
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
I tried to look for the wiring everywhere,but everyone has the diagrams about AEM UEGO . I got an AFX wideband o2 sensor located in a front o2 housing. I got two wires coming out :YELLOW- analog output signal wire. BROWN- analog output ground wire.Which wire i should connect to the ecu,and witch pin i should use to the ecu? Because i connected,and the readings between wb and estafr are not close
IF the wideband controller Has narrow band simulation then look at the manual for the 0-1v output wire and splice it to the front o2 pin.
Ecmlink v3 allows NBS internally by just checking a box.
