1G engine sensors turbo vs. non-turbo
ArcticCatJay
46
Jul 17, 2009
Breinigsville, Pennsylvania
I was wondering if the sensors in the engine are the same between a turbo and non-turbo? Such as the ISC, MAS, Crankshaft PS, TPS?? I have a 94 talon 2.0 turbo AWD 5-speed and I found a 92 talon 2.0 non-turbo 5-speed in a junkyard and I am wondering what parts are the same that I can take off it. Any ideas or help would be great! thanks!
I am having problems with my 94 talon. I'm not sure what is wrong with it. I had a bad idle surge before the car died, which i read is possibly a bad ISC which could burn out the ECU. I pulled the ECU and it doesn't appear to have anything burnt or leaking. when the car died, it just shut off going up the highway, it blew the ignition fuse. I replaced the fuse and it won't start. I'm just trying to figure it out before i go and spend money i don't have, hence why i was going to strip the sensors from the car i found in the junkyard. any ideas????
