Engine reinstalled (bleeding radiator) question
alltheway2drag
76
Jan 8, 2012
Trois-rivieres, QC, Canada
Hi all , just reinstalled my engine and putted preston.
I almost forgot to ask how to bleed the radiator , make sure there are no bubbles in it.
HOW DO WE DO THAT ?
thank-you for your help : )
Fill it up. Start the car and let it run with the cap off. IT will suck some down. Keep adding fluid until it stops sucking it down than put the cap back on.
It can take up to 20-25 min to bleed out all the air. Also, after you drive it and let it cool again, check it again.
I use my large body to bounce the car, to burp the bubbles out.Then squeze the top hose to burp more.Then more bouncing and squeezing.Start car, shut car off.Bounce, squeeze, top it off and should be good to go.
Ohh I also open the bleeder on the bottom of radiator to make sure no rust is in the system.Then top off again.
