2G Engine rebuilds using EVO 6 internals?
don't you mean evo 8/9 internals? they're most likely the same but finding used engine parts off an evo 6 doesn't seem likely. Cause the evo 6 wasn't sold in the US or as far as i know, anywhere in north america.
So anyway, you need to have the cylinders checked. If they have to be bored out, your not gonna be able to use the evo pistons if theyre standard size.
assuming the shit off your engine is all good and same with the evo parts,
use the evo pistons, rods, crank, and valve springs with new bearings and piston rings.
