aspekt9
- 344
- 4
- Dec 25, 2005
Boston,
Massachusetts
So I've been checking out parts for my N/T conversion and here's the list I came up with. Not all parts include prices but I wanted to get an idea of what you guys think. I'm looking for 350 - 400 HP. I'll be posting a build thread once I get all the parts I need.
RTV & Silicone sealer
Antifreeze
oil
oil filter
premium gas
transmission fluid
grease
Engine
Wiseco Pistons w/ rings [8.3:1] (ExtremePSI - $429.95)
BC Spring and Titanium Retainers (Streettunedmotorsports - $225.00)
Eagle H Beam Connecting Rods (Streettunedmotorsports - $309.00)
ARP Rod Bolts (Importevolution - $40.00)
ARP Head Studs (Streettunedmotorsports - $78.99)
ARP Main Studs (Streettunedmotorsports - $59.00)
Cometic Headgasket (Streettunedmotorsports - $89.00)
Sparkplugs BRES7 (Streettunedmotorsports - $8.00)
NGK Wires (Streettunedmotorsports - $40.00)
Turbo Intake Cam
Tap oilpan for return line
Oil & collant lines
Engine Management
Turbo ECU
DSMLink
MMCd
Fuel Delivery System -
Walbro 255 w/ Install Kit (importevolution.com - $99.00)
Aeromotive FPR Kit [SS Line, Fittings, Rail Adapter, Gauge, Mounting Braket, FPR, Gauge] (Importevolution.com - $215.00)
Fuel Feed and Filter Upgrade (Importevolution.com - $117.00)
Tank to Filter Fuel Feed (Slowboyracing - $100.00)
550CC Injectors w/ orings($250.00)
Injector O-Rings (streettunedmotorsports - $16.00)
Resistor Pack
Intake
N/T Throttle Body Seals / Bolts
2g Throttlebody elbow (DSMParts - $45.00)
Vacuum Lines (Roadraceengineering - $40.00)
FMIC Kit [All Piping and clamps] (Ebay - $300.00)
Greddy BOV ()
Turbo Intake Tube (Slowboyracing - $100.00)
Exhaust & Gaskets
Exhaust Manifold
Exhaust Gasket (streettunedmotorsports - $17.00)
O2 Housing
Full Exhaust
Eletrical
o2 sensor (sparkplugs.com - $45.95)
Knock Sensor (JNZTuning - $73.74)
2g MAS
16GA Wire
MBC Hallman ES Boost Controller (Streettunedmotorsports - $50.00)
Transmission
FWD Transmission (Used - $200.00)
Transmission Rebuild (Jackstransmissions - $799.00)
ACT 2600 Clutch and Disc ($350.00)
Turbo
Big 16G
Turbo Bolts & Washers (Slowboyracing - $45.00)
Antifreeze
oil
oil filter
premium gas
transmission fluid
grease
Engine
Turbo Intake Cam
Oil & collant lines
Engine Management
Turbo ECU
DSMLink
MMCd
Resistor Pack
Intake
Greddy BOV ()
Exhaust & Gaskets
Exhaust Manifold
O2 Housing
Full Exhaust
Eletrical
2g MAS
16GA Wire
Transmission
Turbo
Big 16G
