Engine Management
abaddon_baliel
129
Feb 28, 2009
Muncie, Indiana
I'm in the process of building my 420a for 500whp.
Here's where I'm at so far:
Short Block:
Wiseco Pistons Low Compression 8.8:1 $449.99
Eagle Connecting Rods $319.99
ACl Rod Bearings $49.99
ACL Main Bearings $59.99
Melling High Volume Oil Pump $129.99
New Timing Belt $46.99
Timing Belt Tensioner $129.99
Timing Belt Idler Bearings x(2) $87.99
Complete Gasket Set $159.99
Cometic Head Gasket $89.99
ARP Main Stud Kit $152.99
ARP Head Bolt Set $109.99
Cylinder Head & Components:
Stage 2 Port Job $429.99
Crower Stage 2 Turbo Grind Cams $479.99
Crower Springs& Titanium Retainer Set $269.99
PEP Valves $169.99
SBi Valve Guides $59.99
FELPRO Seals $36.99
SBi Valve Lock Set $29.99
SBi PT Cruiser Style Lifter Set $159.99
SBi PT Cruiser Style Rocker Arm Set $159.99
ARP Cam Tower Studs $179.99
Treadstone t3/t4 turbo kit $1800
-Tial 38mm wastegate upgrade
-Turbonetics T3/T4 T04E 50 trim turbocharger
ECU Management:
Megasquirt
I have thousands in other parts but for this purpose I believe only the above mentioned information is needed.
My Question:
I need a good wideband datalogger that I can fit in my dash (where the vents are). I'm not into gauges, so I don't really want any gauges. It needs to be able to work with MS and do everything needed to run my setup.
**I HAVE NOT DONE ANY MODIFICATIONS YET, I AM IN THE PROCESS OF BUYING EVERYTHING**
MS will log (and make use of) wideband o2 sensors. All you need is the wbo2 sensor.
So all i need is MS? I don't need any gauges or anything? Some other members recommended Zeitronix brand dataloggers... so you're saying I don't need anymore dataloggers as long as I have MS?
...Great. :)
He'll also need a wideband controller, like the LC-1 or LM-1. MS can't utilize the wideband sensor directly. The LC-1 will drive the charge pump and condition the output of the sensor to make a clean 0-5V signal that MS can read. You can pick up a wideband kit (I know Innovate makes them) that includes both the controller and the sensor.
You do not, on the other hand, need a gauge or any sort of datalogger. Like Locke said, MS can log and display every input, including the wideband.
I feel like I should have known that for some reason, but I apparently didn't.
That's okay ### I was going to get the "complete" MS kit from symtech labs, the one that includes the ms-II chipset, 3 bar reading, and innovate 02 band and controller. So no worries! :)
Thanks. I hate gauges, and I didn't see how they were required when everything I've read that they do, MS can do.
