Engine Holding RPMs
93RS
140
Oct 3, 2011
Brandon, South Dakota
Hey guys, I just bought a 95 Eclipse RS fully optioned out. Really nice car but when your driving and you go to shift it doesnt let the rpm come down which makes it a little harder to shift. You barely tap the gas pedal just a little bit and it revs to 2k and holds there for a good 3-5 seconds. Other then that my only concern is that is seems slower then my other 420a but that one also has full exhaust. Any help or suggestions would be great.:cool:
Nope haven't tried anything with it. I would consult you guys first. Its getting an oil change and trans flush tom, doubt rather either of those will help but I'll be under the hood. I thought I have another 420a any parts i could swap and try??? How do I clean the IAC???
Just unbolt it and take some carb cleaner and a OLD toothbrush and spray it in there and clean with the brush, then but it all back together. Easy as that.
EDIT: Its right under the TPS if I remember correctly.
When my egr had a vacuum leak, it would hold the rpms the same way so I would check that just in case.
