scottr126
- 366
- 2
- May 24, 2003
CHICAGO,
Illinois
Im currently doing a 6 bolt swap into my 97 GST and the 6 Bolt from My old car was giving low compression readings due to bad piston rings so while I had it out I installed new Piston rings and New clevite Rod Bearings, I did everything to spec and tightened down the rod nuts to 35 ft. lbs. I dont have the engine installed yet but I noticed even without the head on (no compression) the engine is kind of hard to spin, its smooth and all and i dumped a bunch of oil on it but it just seems kind of difficult to move like the only way to get it to spin is put a 1/2in rachet on the crank and crank on it but once u get it goin it goes decently easy, is this normal after new rod bearing, piston rings?
Not because I didn't check ring endgaps, which by the way I did.
. But ya it runs pretty smooth, had a few oil leaks but its all good now. But I still have this weird problem whenever I start it up at first you hear the engine crank then right when it fires up it makes this horrible grinding sound for like a split second but then proceeds to run perfectly and rev perfectly. I dunno what the hell it is it makes me nervous as hell but the motor runs Perfectly. Any ideas?
