Engine dies during gear changes
j23
Nov 12, 2006
Hamburg, Europe
Recently my headgasket was changed, now everytime i press the clutch when i shift the rpm drops and the engine dies. The car idles fine and the problem is happening only if i press the clutch arround 3k or higher and keep it depressed during shifts while driving. I own a 99 GSX and no im not venting the Bov, my boost gauge shows normal vaacum readings.
Please help...
Did you do a boost leak test? Check vacuum lines might have a leak somewhere and don't even know it. Simple boost leak test is brake cleaner or starter fluid and spraying it on lines. Check compress just for hell of it.
We already sprayed brake cleaner all over possible vaccum leak points and i checked the grounding to. Damn my car wnever did that before the gasket job. I also noticed that my idle goes a little down when i press the clutch...
I would have to say, check all your sensor wire connections, and condition of those wires. Being almost a 10year old car, those wires coating will crack off.
Just to let you know, due to the busted headgasket at least 2 quarts of oil were pumped into my coolant systen. Finally i took the oil pan of and discovered my biggest fear a walking crank and knocking rods.
Right now my GSX is getting an evo 3 engine...
An evo 3 is a 7 bolt 4g63... you will be doing nothing but replacing a 7 bolt.... find a six bolt 4g63 and swap it...
What is this and where can I see more pictures of it? :D
