Engine cuts off when turning
iNEEDspeed
30
Nov 24, 2002
Los Angeles, California
I have a problem that only happens when I turn left or right, for example taking a tight freeway offramp. When I do this the engine seems to cut off almost like power is taken away from the ignition system. Once I let off the gas or go straight the engine will return to idle or if my foot is still on the accelrator the engine will start to rev again. This only happens if the turn is tight and the speed is enough to exert some G forces I guess you can say. It happens whether the tank is full or empty cold or hot. It doesnt do it when driving normally.
Thats the first thing that came to mind when this first started. I checked the connections and the battery is clamped down nice and tight. The second thought was crankwlak but that's not it either.
dang... hmm... look for loose ground connections? that battery idea happened to me every left turn i made... left a good nickel sized hole LOL
Yes, it feels like a lack of fuel almost. I will rule that out, hopefully, this upcoming weekend when I have a chance to install a larger fuel pump.
Thanks to everyone that gave me their feedback. I want to say that I replaced my stock pump with a Walboro 255HP and it seems like my problems with cutting out have been cured. I took the car out for a drive and tried to recreate the studdering and it was a no go so I'm stoked. Thanks again.
